    Is there some estimation about how much to back off output power when amplifying a multi-carrier signal? Asking for a friend...
  • rfdave
    I'd assume that you want to back off about as much as the Peak to Average of the signal, so you need to know that first.
  • Sebastião
    Yes, the general recommendation is to back off the output power by approximately 6–10 dB to avoid intermodulation distortion when amplifying a multi-carrier signal. The exact value depends on the amplifier's linearity and the number of carriers.
  • Sebastião
    Feel free to contact me.
    Depends on if you are worried about creating co-channel interference or just distorting your own signal. For the latter, if you can measure EVM on an analyzer then you can generally treat that as an Eb/N0. Say you required Eb/N0=10 dB, then required EVM must be better than 10^(-10/20) = 32 %rms, without taking into account thermal noise.
    From a more analog perspective, you can treat the IMD as the noise in SNR and assume the 3:1 drop-off, so a 3 dB back-off would be a 9 dB improvement in SNR; again, easiest to measure on a spectrum analyzer.
    For adjacent channel, depends on how close the other receiver is, so bigger problem.
  • Hadrien Theveneau
    Hello,
    Many thanks for your answers. I eventually find a way to calculate the requested quantities. I will publish a tech note on the subject on my blog once I finish the typesetting.
    Have a nice day,
    Hadrien
