• Norman grody
    My interest is in the area of microwave radiometry. Most recently I constructed a 1.4 GHz radiometer but found I need to use a filter with no larger than a 27 MHz bandwidth to operate the FCC protected region. So far the narrowest bandwidth I was able to get has a 3 dB bandwidth of 100 MHz. This however is found to be insufficient to remove all interference so I wonder if anyone knows where I can get a narrower bandwidth filter at 1.42 GHz?
  • Norman grody
    My interest is in the area of microwave radiometry. Most recently I constructed a 1.4 GHz radiometer but found I need to use a filter with no larger than a 27 MHz bandwidth to operate in the FCC protected region. So far I was able to only acquire a filter with a 100 MHz bandwidth centered at 1.4 GHz. This is however found to be insufficient to remove all interference. Does anyone know when I might be able to obtain a narrower bandwidth filter?
  • Chris Watts
    Try this one https://www.golledge.com/search/?q=MP01333 . No stock at Golledge so you might want to search more widely for TA0718A.
  • Desert Sage
    Mini0circuits ZVBP-1420-N+ is specified with a 10 MHz BW. down side is $711 price and dwon side $2 is Tpye N connectors.
  • Justin Magers
    I'd take a look at SAW filters. Try: https://www.taisaw.com/
