    Say you had a really nice LNA with 1 dB noise figure expected but you were measuring 1.5 dB. What are the sources of errors? Reflection coefficient of the LNA (which is not good)? Could some low-level bias line oscillation ruin the data? Which is better, PNA with NF option or spectrum analyzer using Y-factor? Maybe that microscope light should have been switched off?
    Or maybe the LNA is not as good as advertised? Obviously, figuring this out should involve measuring a sample greater than one, but that's where we are for now...
  • rfdave
    You've probably figured this out by now, as you're a smart fella, but at one point, Keysight has a Noise figure uncertainty calculator on their website that would estimate how much error there was in a measurement, given the VSWR's and the ENR performance. That might give you some direction.
  • rfdave
  • epos
    Both PNA and Y-factor measurement options are sensitive to oscillations, and external sources making its way into the signal chain. Y-factor measurement depends on VSWR, and for sub-dB measurements, the ENR of the source is affecting the measurements, and can vary with calibration year per year. AFAIK accuracy with the newest USB-C sources from Keysight is in the range of +/- 0.2 dB NF with a known DUT (I have had the luxury of using a PNA and Y-factor equipped NFA side-by-side). PNA measurements are can be difficult as compression will affect the measurement.
    Did some experiments with putting an isolator in front of the LNA and trying to subtract out its loss. It definitely improved the bumpiness on the Y-factor measurement.
    Oscillations are a possibility, when we started taking data the NF was like 10 dB but the amp was singing like crazy. Capacitors and resistors seems to have fixed that.
    I will look at the VSWR uncertainty calculation...
    I think part of the larger picture is that just maybe the noise figure shown in a MMIC data sheet was measured on-wafer, and the user has to suffer some loss mounting it to a circuit board. For yucks we might but a Qorvo CMP2626 LNA eval board
    https://store.qorvo.com/products/detail/qpa2626eval-qorvo/597407/
    But it does not appear to have a "through line" to calibrate out the board losses.
  • rfdave
    I came across this
    https://www.highfrequencyelectronics.com/Jan10/HFE0110_Marsan_Part1.pdf from the 2010 High Frequency Electronics on measuring sub 1dB NF parts. I haven't scrubbed through it, but it might be applicable. there's a P2 as well.
