KJ7LNW
With microstrip, a portion of the electric fields are in the dielectric between the strip and the ground plane while other fields exist in the region above the strip with air as a dielectric. At frequencies where the electrical distance in the dielectric material between the strip and ground plane is much less than a wavelength, microstrip behaves as a non-dispersive TEM line.Unlike moding in pure TEM lines, the transition in microstrip from TEM to quasi-TEM is not sudden. With increasing frequency, as the substrate thickness of microstrip becomes appreciable, the propagation velocity and the characteristic impedance of the line increase. — HF Filter Design and Computer Simulation
UnknownEditor
UnknownEditor
Hadrien Theveneau
JP22
UnknownEditor
