    fff created the topic: Tuning U.FL / Antenna Cable Assemblies
    Cellular, Wi-Fi, GNSS and Bluetooth radios are available as FCC-certified modules with a U.FL connector that connect to an external antenna through a cable assembly. Why do you never see an antenna matching network in finished products that use this approach?
    N10sive replied to the topic: Tuning U.FL / Antenna Cable Assemblies
    If you are talking about a module, it is most likely the supplier assumes a 50Ohm line and that the U.Fl SMT connector is 50Ohms.
    In a finished product with an antenna, the manufacturer has most likely "tuned" the antenna to the desired frequency without using a matching network.
    In the case of cellular, it is also difficult to have a desired matching network, for a multi-band antenna etc. There are also less stringent parameters specifications for VSWR in cellular, at least in the lower bands.
    This is also due to cost, efficiency, space-constraints, etc.
